Congrats.. You will be a happy camper when you stand on the gas... only problems I have are minor.. wires pulled out of connectors hooked to wires ( black & orange) from MSD box as I was hooking up shift light and putting tie wraps on..and car would not start...these should probably be soldered as over the years I have had more than 1 wire connecter fail .. also wiper on passenger side flops around.. took it apart there is a little shim with teeth on it that are stripped... under the wiper arm itself.. with 17" wheels and tires you really dont need limited slip.. plenty of traction.. shift light is a plus as I bounced off the rev limiter more than once in 1st gear...bought on ebay $50 delivered & no tach needed as it has a dial on back to set RPM's have fun & be careful as the grin on your face may not wipe off...
Like a kid in the candy store I just can't get enough
Current rides GT500 & Backdraft
