Old 12-24-2004, 08:13 AM
Big-Foot's Avatar
Big-Foot Big-Foot is offline
Cobra Make, Engine: RCR GT40 #45
Iskendarian makes a Piston Notching tool - you can get more info from their website:
http://www.iskycams.com
I have tried to capture some of the data below - You use your cylinder head as the support platform / mandrel for the tool and cut the pistons while they are in the bore.
Piston Notching Tool
Many racers purchase custom forged pistons made to their engine specifications then find (and usually too late) that they have V/P interference
(valve to piston interference) usually caused by mislocated valve pockets in the piston's domes. Only ISKY markets this tool where your own cylinder
head is used to obtain perfect geometry with the valve that cuts its own proper relief in the piston dome. Available in 1 5/8, 1 3/4, 1 7/8, 2, 2 1/16,
2 1/8, 2 1/4 and 2 3/8 inch diameters for nearly any engine requirement. Proper procedure, is to choose the next larger cutting size than your valve
diameter, for proper valve pocket side clearance. Pilot sizes are 5/16, 11/32 and 3/8 diameters. Perfect for the Racing mechanic or speed shop, the
tool may also be rented at a nominal fee.
Cutter only (specify size) (hand driven with tap handle wrench) . . . . . . . . . . . . . . . . . . .NET $100.00
Pilot (specify stem dia.) (hand driven with tap handle wrench) . . . . . . . . . . . . . . . . . . . . .NET $32.00
(Rental charge) refund due customer when returned (for 1 pilot and cutter) . . . . . . . . . . . . . . . .$40.00
*Above Prices are net, no further discount.
P.N.T. Cutters P.N.T. Pilots
Part No. Diameter Part No. Pilot Diameter
PNT-158 1 5/8” NP-516 5/16”
PNT-134 1 3/4” NP-1132 11/32”
PNT-178 1 7/8” NP-38 3/8”
PNT-200 2”
PNT-216 2 1/16”
PNT-218 2 1/8”
PNT-214 2 1/4”
PNT-238 2 3/8”
NOTE: This Tool is effective for cutting eyebrow only (up to a 50% valve face
area cut). Beyond this point efficiency is significantly reduced.
Isky Invention
Regards - Randy
RCR40 #45 http://www.GT-Forty.com
