Old 12-25-2004, 03:28 AM
mikey mikey is offline
Default Tremec Sender Question
Having purchased a speedo sender plug from Classic Chevy, I am not sure I have chosen the right one - ie is the older Tremec and newer 600 different
The attached diagram shows the problem. The pins in the Tremec do not match with the ones on the sender. If the plug is pushed in they locate to either side with the plug body spacing them.
Anybody know if this is right (ie they sense the signal through the plastic body or do they have to mate as I think they probably should do. Your comments would be appreciated. The box is a TKO 600 by the way.
Thanks and Happy Xmas Guys.
Mikey B
