Old 12-25-2004, 09:08 PM
Keithc8 Keithc8 is offline
As I said I will match the price on the out of box heads and treat you right on the shipping. Our stage 1 head runs 1495.00. We start with a bare castings, use our special order valves, our valve job for best flow, cut the valves to proper angles, bowl port and work the shortside, vacume test, cc chambers and mill to the desired specs, deburr, chamfer, clean and assemble with spring cups, dual springs and 10 degree retainers and locks[they come from Edelbrock with 7 degree retainers and locks]. We supply a build sheet with the parts used, assemble heights and spring pressures.
In your case we could use a 2.15 intake valve and the 1.66 exhaust valve for best results. Thanks and good luck, Keith
Keith C
