Franko Go get the car wieghted and balanced in all 4 corners first. Make sure you have your wieght in the drivers seat. After you have the car scaled then you can work on the suspension by changing the dampeners around to get the ride you are looking for. Most Cobras only sit 4-5.5" off the ground. You do have to watch bottoming out. Scattershield bell housing is the lowest point if you have a speeder in the car. Find a dirt track racer with scales to help you get started. You will fell the differents when done. Go luck Rick Lake. Ps have the car get a 4 wheel alignment after the scale work is none, then go eat a vette.
Rick Lake
