Old 12-27-2004, 05:22 AM
Big-Foot's Avatar
Big-Foot Big-Foot is offline
Cobra Make, Engine: RCR GT40 #45
Roy - The aluminum head will dissapate heat quicker than will the iron head. It will also let you get away with a little more compression on today's pump gas - although Ron Widener here has found out, you really can't get away with a lot. With aluminum heads we typically will set the maximum pump gas compression at 10.5:1 for a "Sunday Competition" engine, and then 10:1 on cars that will rarely see the track.
Your engine would really like a set of AFR185 heads. The ports are not so huge that you loose the all important velocity for docile street driving.
Regards - Randy
RCR40 #45 http://www.GT-Forty.com
