Old 12-27-2004, 11:33 AM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
The spcns (specially constructed sequence number) should be able to be generated as a separate operation from the registration. The receipts are used to determine value and as a basis for fees. There are no fees collected to generate a spcns number.
It may be necessary to have gotten a vin / processed a mso prior to being issued an spcns. Nothing works at DMV without a VIN. Hopefully he has already gotten his car started in the system. We have a pool about when the 500 spcns numbers for 2005 will be gone. Last year 2004 it was 45 days.
Remember sb-100 is only a means of vehicle smog exemption, not registration. Registration includes processing the MSO, processing a VIN. CHP inspection, Headlamp and Brake inspection, etc. The sb-100 component is only one way of dealing with smog testing. The old method of using date of engine manufacture or date of chassis fabrication is still in use.
Lets say the car has an engine from a 1978 ford truck. All 1978 emissions equipment must be present. This is why early component car builders used period engines. If the car had a 1966 engine then it was required to have 1966 smog equipment., etc.
I saw a 1966 428 block in the parts for sale section of the fourm
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
