Old 12-27-2004, 03:42 PM
Wheels427 Wheels427 is offline
Cobra Make, Engine: ERA 390 Stroked to 418
Thumbs up FFR 3881K with 427FE
Non Donor build finished summer 04,The best of everything used in build. E-mail me if want to see pictures as I don't know how to post them here. Ready to show or drive.
Body
Titanium silver with black stripes
Bodywork and paint by Ron Randall, so you know it is gorgeous
Underside of hood with Ron Randall's famous aluminum process
Ron also sprayed the underneath with Body Shulz
FFR hood hinge and supports
wipers
front and rear chrome overrider bumpers
Front chrome bumper loop
Sunvisors and glass windwings
powder coated gloss black rollbar
trunk support pistons
Raydot mirror with windshield mount bracket
Custom plaid trunk mat like Ford used in mid-60s
Drive Train
1964 FE427 centeroiler, .030 over TRW pistons
Edelbrock Performer alum. heads
Blue thunder repro 2x4 med. riser alum. intake
2 Holley 470 carbs
Stock solid lifter Ford cam
Edelbrock alum. water pump
polished 1 wire alternator
stock dual point Ford dist. with Petronix electronic conversion
pent roof chrome valve covers with 427 emblems
mechanical and elec. fuel pumps
Custom alum. radiator by Russ Davis with dual fans
breeze thermal fan controller
4 speed toploader with Hurst shifter
modified Lakewood blowshield to use Mustang clutch cable
Mcleod clutch and pressure plate
3.55 Ford gears
trick flow rear end cover
Lokar throttle cable
Loback mufflers welded in, then hot coated black
Suspension
3 link rear suspension with coil overs
FFR rear lower control arms
FFR front lower tubular control arms
Flaming River steering rack and linkage
Breeze tie rods and alum. rack bushings
5 lugs with repro Halibrand wheels and spinners
Jeep master cylinder
metallic brakes front and rear
powder coated rebuilt front calipers
stainless braided brake hoses
stainless brake and fuel lines
Interior
FFR Street Performer seats
ultralite gauges including clock
Fiero parking brake next to driver's seat
Turn signal switch and gas pedal from Russ Thompson
AC repro pedals, including on dead pedal
Whitby heater/defroster
door panels with map pockets
Repro shifter arm and knob
Cobra earls powered interior vents
Finishline floor mats
$42,000
Paul Wheeler
located in Northern Connecticut
