shocks
yes mine were gabriels. on your shifter check and see that the shifter is properly shifting with the boot off. My shifter needed more room as it was hitting the trans tunnel. I took a air saw and cut a bigger hole problem solved. Have you had any problems with springs?
Later dennis
