Nothing fancy (assuming your engine is a 64 or later block). Just the standard Lakewood scattershield for the Ford FE. The only trick as I recall is that you'll need to buy your clutch disc seperate from the pressure plate. That's because you need the pressure plate to bolt up to the ford flywheel but the splines on the Richmond 5spd are 26 spline. Ford never offered a 26 spline clutch disc so you'll end up using a clutch disc from a Chevy.
Chris
