Old 12-31-2004, 07:11 PM
Big-Foot's Avatar
Big-Foot Big-Foot is offline
Cobra Make, Engine: RCR GT40 #45
Webers look awesome but they are a brass-plated-b!tch to keep in tune... The slightest bit of dirt in an emulsion tube will give you a carb that sputters, burps, backfires and generally runs like cr@p.
Now that iI've given you the bad news - The throttle response is pretty good, but not as good as a single 4bbl that is setup right. These carbs are meant for mid-range to top-end and really don't like low RPM use. When tuned right they are sweet as you can find. When in the proper RPM range, they will pull you off a corner like nothing else short of a good EFI system as they are darned near immune to cornering forces..
Regards - Randy
RCR40 #45 http://www.GT-Forty.com
