Thread: Rippin' into it
Old 01-01-2005, 03:42 PM
Bish Wheeler Bish Wheeler is offline
Cobra Make, Engine: A&C 427SC #188 ZZ4 Crate, Tremac 3550
Send a message via AIM to Bish Wheeler
Been taking the shoe off for 4 years! There is so much room between the footwell and the transmission it seemed like the thing to do. Should be fairly simple to cut it out, make a sheet metal insert which will be pop riveted in place and then glassed over. Will use a cable drive gas pedal and spread the brake and clutch. Using the cable drive will remove the throttle linkage lash up and clean things up. Anyway, looking forward to not having to wear special shoes or go barefoot.
Happy New Year you guys,
Bish
