Old 01-03-2005, 05:05 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Hi David,
Mines the 14" version. I think the 15" wheel is going to be a bit snug next to the door. Besides the steering with the LS1 in the front is pretty light so you don't need the bigger wheel.
Mando, as Bernie mentioned there is a boss on the back of the pedal you need to machine to fit the arm. I machined a slot in each one and then drilled and tapped them. A bolt runs through the boss and throug the end of the arm. There is a nylock that acts as a lock nut.
My pedals are set up to pivot inder your foot. This makes them a bit more comfortable as you press them as they stay flat with the ball of your foot. I bent up some springs to keep them straight and aligned and stop them rattling. I did a set for Phil and he reports that they feel natural under foot, you don't even notice them.
Mike Murphy
Melbourne Australia
