Old 01-03-2005, 09:11 PM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Hello Mike, Would you be able tell me whihc flywheel you are using and the part numbers you used in your West Coast for the Mcleod disc and pressure plate? I plan to use a Tilton Hydraulic release bearing, which bearing are you using and how has it been? Oh yeah one more question, what size hydraulic master cylinder are you using ,a 3/4" bore or a 7/8" bore and which brand are you using, Tilton, Wildwood, etc ?? Vern used a 3/4" bore Wildwood in my chassis and I am contemplating moving up to a 7/8" bore size since this is what Tilton advises in their literature.
Thanks for the feedback
"...some assembly required, ages 8 and up...... well that took longer than expected......
