  #34 (permalink)
Old 01-04-2005, 04:59 AM
Cracker Cracker is offline
Aviaid - I have one these pans and it sprung a leak in the center of the front bottom weld. It now leaks all the time but profusely when the oil gets hot. The plating is the reason I haven't wanted it fixed locally but is this something that can be "sprayed" on or does th pan need to be sent back the factory to MAKE IT RIGHT? They aren't suppose to leak, correct? Thank you!
