Old 01-05-2005, 10:24 AM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
For the power you are producing and the application you qoute I would consider something like, for example from Aeromotive, this system as a minimum.
12303 fuel filter to a 11203 pump to 13301 bypass reg to the carb and tank. DO leave the float bowl filters in. -6 and 3/8" line will be fine. Do not run braided line all the way to or from the tank, only where required. Do not use 90 degree fittings unless you have to and if so use the 'full flow' type of fittings. This will be fine for 'spirited' street driving and the occasional trip down the 1/4. If you are going racing, check back!
Rick
OhioCobraClub.com
LondonCobraShow.com
