Old 01-07-2005, 07:22 AM
Terry Stapley's Avatar
Terry Stapley Terry Stapley is offline
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Brent, I did mine the way you are thinking and it worked out great. The tabs in the first photo are for the belt mounts! I drilled a hole through the frame kickup and put a hole in the upper trunk bottom so the belts bolt directly to the frame. Just enlarge the hole for the rollbar support on the drivers side.
Terry
