Old 01-10-2005, 02:05 PM
hydra hydra is offline
Cobra Make, Engine: FFR, sbf
Default 1998 Ford 5.0 World Class + T5 transmission + COMPLETE wiring harness & ECU
This is a 1998 Ford 5.0 with GT40P heads and intake manifold, as well as the larger 65mm Throttle Body. Heads have been ported and polished, and milled for higher compression. Similar engine combos have been dynoed at around 290-300bhp... There are approx 40k mi on the engine and around double that on the tranny, which is from a \'94 ford mustang. Tranny shifts great - no problems whatsoever.
I\'m also including the COMPLETE wiring harness with all the necessary sensors, injectors, and ECU. Basically, you\'ve got EVERYTHING as far as the drivetrain is concerned... Best offer takes all... Email me
