Old 01-12-2005, 07:45 PM
sshurts's Avatar
sshurts sshurts is offline
Cobra Make, Engine: Kirkham 427 S/C #253, KCR Built CSX #452
David,
To you and the crew, this is a Great start and I look forward to the continuing chapters.
In addition to the many obvious areas that are still in the works, may I suggest a way to request Patterns for things.
For example,
my carpet came in a roll,
the rubber matting for the wheel wells seems to have patterns that you use
the cutout for the sidepipes
others???
Somewhere on the list might be some optional work (I know first things first).
For example,
What if I want to run a double fuel pickup system?
What if I want to run a return fuel line?
What if I want to put the fire system in the trunk?
What if I want to put a breather differential catch in the trunk?
Don't forget the, what if I want to rewire the dash section
Also, don't overlook the opportunity to go over the simple things too. As you might have observed, Morris has a great writeup on ANs hose fittings. Actually, Morris has numerous writeups, all of which are great!!!
Other great suggestions on wiring and component quality from Turk. Pat Buckley has modifications unlike any others too -- love that windscreen Pat... Lots of wisdom around that helps in finishing what KMP started... Heat reflection in the engine compartment.
It would be nice to have a section (or web location) where owners couple contribute customizations that they wish to share.
I'm sure that KMP has tons of ideas too, and it all begins with a start --- thanks for hearing the people.
This is HUGE winner for ALL.
Thanks
Scott
