Thread: Fan Shroud?
Old 01-13-2005, 12:54 PM
flipper35's Avatar
flipper35 flipper35 is offline
Cobra Make, Engine: Shell Valley, Mopar thingy (small block of course)
Just switched from a pusher (16" Permacool with fabricated aluminum shroud) to a puller. The puller should be in tonight and will let you know. The pusher had a small shroud around the blades only. The new one is slightly bigger, but still not a full sealed shroud. The pusher never did keep the real cool at idle, it would get above 210* in the 110*+ heat here but would keep it below 200 back in Wisconsin.
Brent Dolphin
