Jim,
Check with Don Scott first on things you want to do to
your Cobra and I'm sure he can give you the best advice
on what will or won't work. He should also be your first
stop to shop for parts since he builds them.
You might check Tony Branda for the wood steering
wheel, and other goodies (just another source of Cobra
accessories).
As for the rattle on your side pipe, check the end mounting bolt for
tightness. Mine developed a rattle and it went away after I found
the loose nut and tightened it.
Hope this helps - and I know you will enjoy the car - I've had a blast
for the last 4 years with mine.
Flip
