Jim:
Thank you! I thought that it should read around 15 or so volts pretty near all the time if the darn thing was working, and certainly more than 12.6 or so.
So here I go again.
I don't think the battery is the issue as it cranks the engine just fine. If it had a short between cells I would have thought that it wouldn't crank the engine. Is there a more sophisticated battery test that should be done, or other battery fault that could be contributing to this?
Also, when I started the car this morning, cold, the alternator still did not come on line. So I don't think it is a heat problem.
Time to take it to an expert I reckon.
Any other suggestions would be welcomed!
Thanks
Bill
Bill
"If your work speaks for itself, don't interrupt"
