Old 01-17-2005, 06:04 PM
cobred's Avatar
cobred cobred is offline
Cobra Make, Engine: ERA #698 428 Toploader
Default Blue Thunder manifold question
Could some members tell me what they use for a pcv set up with the Blue Thunder manifold on an FE engine? I want to use the pent roof valve covers with no breathers if possible. Can you use a plate at the rear of the intake and install a grommet? If so do you need a baffle under the pcv to prevent oil consumption? Thanks, Ed
