weber input
maybe you weber gurus might have a suggestion on a good starting point for my 48 ida weber endevor, a-top a 351 windsor stroker 427 cubes.
current
choke 42
main 175
e-tube F7
air corr 155
idle 60
idle air 60
pump 45
pump exaust 80
3 progression holes drilled
compression ratio 10.5-1
cam specs- hyd roller,1.6 rockers
duration advertised 304 in 304 ex
duration @ 50 244 in 244 ex
lift 576 in 576 ex
lobe sep angle 110 deg.
any sugestions to these current weber settings would be greatly appreciated.
Regards Carmine
