Old 01-19-2005, 07:01 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
69 Mach 1,
Iam not sure about the victor series water pump, but if it won't work and you have room you might do what a friend of mine did. He brought the hose out of the bottom of the radiator and made a curve so it didn't pinch shut. Then he got a stainless steel pipe and put it in the end of the hose and ran it across to the other side of the engine down at the bottom. He then took a hose from the water pump and brought it down to the pipe and hooked it up and he has ran this for a few years with no problems.
I am sure some of the others can tell you about the water pump and if it will work. I have a Flow Kooler aluminum pump on mine and had the radiator built with the outlet on the passenger side.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
