Old 01-19-2005, 02:10 PM
69 Mach I's Avatar
69 Mach I 69 Mach I is offline
Cobra Make, Engine: No cobra YET. Making do for now with a 69 Mach I
Originally posted by Roscoe
I guess you can call Edelbrock to answer your question on the right/left thing.
For right side, you can have your radiator modified with a -16AN fitting. Get a Goza adapter for the pump: hose to AN. And run AN braided hose. You will only use a small 4" piece of hose for the adapter. I run -16AN top and bottom.
Roscoe
I just got an email from Edelbrock and there is a difference between the 69 and 70 waterpumps. the tech guy who responded also recommmended switching the outlet to the other side, which I did not know was possible. I contacted the guy who built my engine and he told me not to worry as he used a special radiator hose from Dayco pre-formed for my application.
