Old 01-21-2005, 06:14 PM
Rebel1 Rebel1 is offline
To follow on from Thomas Gayer's post. I did add relays for the radiator fan and used the painless fan switch circuit to switch the relays and I would use the aircon compressor switch circuit to switch relays for an elec fuel pump.
The only relay supplied with the kit was for the horn.
I did have to add a few little bits of wire to existing curcuits. Like the side indicators we have to have in Aussie land...this was just splicing a short pigtail to the existing indicator wire.
Ohhhh...the only real addition was a circuit for the windscreen washer.....but that was easy. I just fed that from the painless supplied wiper cuircuit which is heavy enough to feed the BMC wiper motor but you might want to add a wiper relay to save your switches.
