Thread: 427 side oiler
Old 01-23-2005, 10:06 PM
shelbygt350s shelbygt350s is offline
Default 427 side oiler
427 SIDE OILER ENGINE FOR SALE 22,500.00 or obo
THIS ENGINE STARTED WITH A STANDARD BORE BLOCK AND STILL IS STANDARD BORE .IT HAS LEMANS ROds ,SIMI-DOMED PISTONS AND STANDARD CRANK .CRANE -CAM GRIND # 290 .THE HEADS ARE NEW 427SHELBY SIGNATURE SERIS, MEDIUM RISER ALUMINUM. THE HEADS WERE PURCHASED NEW FROM CARROLL SHELBY ENTERPRISES.DYNO -RUN MAX POWER =297.6 ,MAX TORQUE 353.8. THE ENGINE HAS APPROXIMATELY 300 MILES ON IT. THE ENGINE WAS ASSEMBLED BY BLISS PERFORMANCE ENTERPRISES ,SPANWAY ,WASHINGTON .ALL PARTS ARE NOS OR STANDARD . THE ENGINE CARIES 80 IBS OF OIL PRESURE WHEN WARM .THE ORG OWNER OF THE ENGINE HAS PUT OVER 20,000 IN ENGINE . YOU GET A LONG BLOCK ,OIL PAN ,WATER PUMP AND NEW HEADERS .YOU CAN HEAR IT RUN IF YOU WOULD LIKE BEFORE IT IS PULLED
