Old 01-24-2005, 03:17 PM
grego37 grego37 is offline
Im running adjustable Koni's up front (mid adjusted)
Im running Global west front coils 620lbs (540,620,680) perf. sm.block weight
I had a set of Goodyear F1 go bad ,not too sure on the exact details I think they ended up with a flat spot?, but luckily I purchased road hazzard warranty and they were replaced.
The specs global west reccomended were
Caster: +2deg (pass side)
+1.5 deg (driver side)
Camber: -1/4 deg
Toe in: 1/16
I dont remember exactally but they got close to these #'s
as far a parts loose, everything from what I can tell is tight and tourqued with cotter pins etc...
To test ball joints, I jacked car up , grabbed the wheel and tried to move it from 6 o'clock to 12 o'clock . Im a big guy, and I couldnt get any movement. The lower ball joints were new with my new lower arms last year.
any and all parts are basically new; tie rods, tie rods ends,
I'll get back under there tonight and tripple check everything.
Boy, this website is awesome.
Thanks for the input, keep the ideas comming.
