Old 01-26-2005, 10:08 AM
DaveR DaveR is offline
Club Cobra Member
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
Scott and Jon,
This is a wierd thread! Do a little research and you will find that the balance bar is the "optimal" system. When I bought my Wilwood brakes the written instructions said exactly that. However, they also say that most people use the "less than optimal" proportioning valve solution because it is easier to install. I spent many hours switching my system from single piston/proportioning valve to dual piston/balance bar. It is also safer because of independent circuits. Good luck.
