1) 460 Ford + .030 D1 block fully deburred and casting flash removed, L2404 forged pistons and moly rings, polished truck/CJ rods w/ARP bolts, stock 460 crank 10-10 w/ Clevite brgs, precision balanced, (1) C8VE, and (1) D0VE head, stock valves, screw in studs, Isky 5/16 pushrods and guide plates, Isky chromoly retainers, Boss 351 adjustable rockers, poly locks. Melling hydraulic torque cam, 490"/515" and 204/214 @ .050". Cloyes true roller, Truck rear sump pan w/ stock
oil pump. M/T finned alum. valve covers. Will consider cam/spring change. Will add roller rockers for extra...zero since freshened up, ....$3500.00/ offer.
(1) set Manley sever duty 2.25X 11/32" stem intake valve, BB Chev stock length, 28* backcut, new, $120.00
(1) set, import (Competition Products) severe duty 1.88X 11/32" stem stainless exhaust valve, BB Chev stock length. Comparable to Manley, new, $100.00
(1) set, import stainless one piece int. valves, 2.25 X 3/8 stem std. length for BB Chev...new...$75.00
(1) set, Manley severe duty 2.25" stainless intakes stock length for 429/460, fresh grind, backcut, stems excellent...used...$75.00
(1) set, intakes and exhaust, Ford oem 351C 4V valves. Performance backcut on intakes. Complete, new...$100.00
(1) pair Ford C4AE Big Port FE heads. No sunk valves, good condition. These are listed as one of the best choices for factory iron FE heads...used... $400.00/ offer.
(1) Cast iron 429 CJ intake manifold...used...$150.00
(1) Cast Iron 429/460 bell housing, flywheel, pressure plate and disc. Good cond. OEM HD clutch...used...$200.00
(1) Cast iron small block Ford Bell housing...used...$75.00
email
scotfox@earthlink.net
