Okay got 250 miles on 211 now and the car is awesome.
Anyone have tips on the best hardware to mount the fire ext with. I want to mount it just under the dash at the forward most part of the transmission hump.
Next what type fluid for the clutch slave cylinder and how do you know it's full.
So far I've lost 4 header bolts and one valve cover nut. Farnk sent me replacements today and I fixed the problems.
Also I ordered the cobra valve covers. It appears they aren't really for this application. The grommet where the pcv valve goes is to small for the hole in the valve cover. It appears this hole was really intended for a
oil filler location or spout. Any suggestions on this. I spoke with frank and he said a larger one is on the way.
I'm skeptical if this will work because the hole is not round it has two ears on opposite sides of each other.
I'm also looking for the dimensions for the cobra badges on the hood and trunk. Has anyone glued these on?
