What heads do you have on the car now? I put down 280 rwhp with a terrible tune (way lean) on AFR 165 heads and a mild cam. RWTQ was 298 on that tune. I'm going back to the dyno when the weather clears with new jets.
throw some good heads AFR, TRickflow, or edelbrock a decent cam, and a rpm air gap and start tuning. Don't worry about what the dyno says just use it to tune and take it to the drag strip.
Good luck. You can go a lot faster then you can problably drive with a good 302. I've learned more about tuning a car with this engine then any car I've had.
