  #21 (permalink)
Old 01-28-2005, 08:47 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
When you hit the brakes on the Cobra do you feel a "pulsing" which is fast (at higher speed) and then slows down (as your speed slows)? This is typically the sign of a warped rotor(s). The pulsing is felt at the steering wheel and the brake pedal whilst braking if from the front wheels and sometimes from the brake pedal and stick shift if from the rear brake rotor(s).
Almost all disk brakes will eminate a slight "schooop schoop" from the wheels when they are spun (the noise coming from one or more pads slightly touching the rotor). However if you feel some stronger resistance and then a release while spinning them then you may have a warped rotor.
Last evening, when thumbing thru the latest Hemmings Muscle Machines magazine, I noticed a firm with a half page ad advertising an aftermarket universal joint, for a steering column. This joint appears to have an integrated judder dampener in it. Kind of like a rag joint but not visible. Interesting. And probably a solution to many a problem.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
