Old 01-30-2005, 08:09 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
I'm also using the Canton thermostat and 1qt Accusump. Photos in my gallery, look for "oil and coolant plumbing". The Accusump is mounted on the front cross brace and plumbs into a T on top of the oil filter. The Accusump is used as a pre-oiler. The thermostat is mounted where a remote oil filter mount would go on the front of the engine and plumbs into a standard sandwich plate.
I choose the Canton thermostat for the same reason as David, it's opening temp. Most of the others open aroun 180 and I don't feel that's high enough for the condensates and contaminants to boil off.
I can watch the oil temp gauge stop climbing when the thermostat opens although I'm in a relatively cool area (Oregon) it still gets pretty warm in the summer. In the cooler winter weather the oil temp never gets high enough to open the t-stat.
DonC
