If all other lights are still working, I would check the brake light switch. I am not sure where yours may be mounted, but I have seen everything from a bad switch to a wire coming loose. If the switch and wires are good, try measuring the voltage through the switch with the brake pedal pushed down. You could possibly have a short to ground in the wiring.
