I'm not sure you will be able to use either in a hot environment. Sikaflex 260 is a good weatherproofing adhesive to seal welded joints and bond non structural elements, inner and outer body panels to keep them from flexing, rattling and vibrating.
Most radiator supports are mounted to the frame or psrts of a sub frame. To bond a vibrating piece of machinery prone to thermal expansion to fiberglass is asking for trouble and will probably break loose sooner rather than later.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
