Old 02-03-2005, 04:21 AM
Dan The cradle is made in a jig. I have inboard brakes and had the same problem. I oblonged the holes where the lower rod goes through. This is not right but worked for me. Doug checked it out and said I was 1/2" off in toe but I checked it on the alignment rack and with my 220lb in the car it comes up fine. I would like the small blocks at the bottom just tac welded, this way you could but the rear in, adjust plates, remove have welded and coated and reassembled. Rap it in paper before you put the rear in the car, it saves the paint. Rick Lake
