When I used my Holden aluminium mount on the right hand side I was 55mm out.
I took the mount to a local welding company and with the flat part that the rubber sits on sitting horizontal on a bench, they cut 55mm out of it and welded it back together.
When I bolted it to the block and fitted the rubber mount then lowered it onto my chassis it fell straight into the hole.
I will try to get some close up pics this weekend of the mount so you can see where it has been welded together.
Cruising in 5th
