Thread: Power brakes
Old 02-03-2005, 12:08 PM
TonyMadrid's Avatar
TonyMadrid TonyMadrid is offline
Cobra Make, Engine: A&C 351W, C4
Default Power Brakes
Hi,
I built an A&C and originally had manual brakes (separate Wilwoods with a balance bar) but I wanted more braking power and swapped for a boosted unit.
Problem I had was sufficient clearance between the footbox and the inner fender. I used a unit from a 1974 Vette which A&C had recommended. Only thing I had to do was cut a relief in the inner fender for the front of the master cylinder. The unit provided unbelievable stopping ability. I am now in the process of covering the relief hole with fiberglass building a recess for the MC.
Also, the '74 Vette has an integral proportioning valve eliminating the need for an in-line valve.
I don't know what kind of room you have for the swap, but I thought this might give you some ideas.
Some guys also have used a Gran National Powermaster unit that uses an electric remote vacuum booster.
Tony
