Anti freeze is not a good conductor of heat. Water is better, that said if you live someplace it freezes antifreeze will keep your engine from being destroyed, particularly an older V-8.
Water wetter breaks the surface tension of water allowing it to fully conduct heat away from your engine. You've all seen water beaded up on a flat surface? Why do you suppose this happens? It's under tension. Ad water wetter... That same small bead of water flatens out like a dime or flatter.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
