Old 02-06-2005, 05:23 AM
keane keane is offline
Default coolant header tank/tranny cooler
Hi, just about to fabricate a header tank, thinking of using 4" ally tube, cut/welded with bottom feed and overflow etc, will fit on the rear bulkhead of my Dax cobra, not sure of the size of tank required? seen others but want to get it right, what capacity would suit?(BBF 429/C6) and what are the normal pipe sizes for the feed/overflow etc. Also trying to sort out the oil/Tranny cooling, what row cooler for the engine oil? and where do you guys mount your Tranny coolers for those running Auto? Are the combined Tranny/engine coolers any good? that would help with the space issue, vehicle is for street use generally, thanks for any advice offered. Dave
