Old 02-07-2005, 01:46 PM
ItBites's Avatar
ItBites ItBites is offline
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
You should do your own alignment. If you're careful, it will be superior to any you will get from an alignment shop. I do my own and find it much better than the service I've gottne in the past.
There are several resources on the web that have descriptions of home-grown alignment methods. A google search will turn up a few.
I do caster and camber with a calibrated 18" carpenter level and a feeler gage stack and use a little trig to get the angle.I set the toe on the front and rear with strings outboard of the wheels that are parallel to the car centerline and a 12" machinists rule. It usually takes me most of the day to do the alignment, but I find the results infinitely superior.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
