400TT / OZVENOM Suspension Querry
Gentleman
Like your vehicles I have a R32 GTR rear suspension setup. To attach the shock/spring units I fabricated brackets to clamp on to the hub carrier. With the suspension now attached it is 50mm higher than if I had used the cast iron hub carriers. I am using King Spring Pt No KPS 188 250lbs.
Are these the springs or eqivilant the ones you used or if they are not what springs would be the best to use.
Warren
