Mine are the flat brackets shown above...I had them made with no holes since the windshield on the BDR is different than FFR, Classic Roadsters ect. I made a paper mold from the flat bracket then took a punch and marked "punched" where the holes are..then transferred to the flat bracket. This bracket is flat aluminum billet cut by a waterjet. The edges are still sharp so a light file and wire brush will ge the brushed look...then spray with laquer spray and your there. You can mount these right/left...you locate and drill the holes...same bracket used on either side.
Jay...did you get those floor mat pics???
