Old 02-10-2005, 05:28 PM
Base733's Avatar
Base733 Base733 is offline
Cobra Make, Engine: Unique 351W
The problem is a bit of an erratic response when opening the throttle. Sometimes it hesitates and other times it doesn't. The carb was recently rebuilt with all the gaskets and power valve replaced. The accelerator pump was also looked at and seemed to be working fine.
I thought that the dyno might be able to diagnose the problem but maybe the Sun machine is a better solution as this is not a fine tuning type of issue.
