Old 02-12-2005, 07:17 AM
cuda66273 cuda66273 is offline
In layman's terms...
They grind the split duration to make the numbers attractive then put a big center line on it like 112 or 114 to take away all the cylinder pressure....it's a scheme dreamed up by the marketing departments so they can sell you a cam that's too big for your combination and it'll still run decent.
True power is built from square cams like 530/530 lift at 242/242 duration at .050 and to increase scavenge balance between the intake and exhaust you use a combo rocker arm system like a 1.72 intake ratio and a 1.6 exhaust.
Here's a good tech article that reallly explains the truth about cams and why they make power...Compliments of the now retired Harvey Crane:
http://www.4secondsflat.com/Cam_Design.html
After reading this you'll realize that all the glossy pages and fancy catalogs are really just a bunch of hocus pocus, real cams are selected and ground by small obscure cam companies like Racer Brown and have been for over 50 years.
"You Can Never Exceed the Speed Of Your Wallet"
