Old 02-12-2005, 10:04 AM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Oops.... Oh well....there were lots of bidders on the shocks. They are part number 3336 and are 9" closed and 12" open. I can just resell them back on the bay.
Sure....whatever package works the best and is available will be fine as long as they work with the pole position A Arms.
Thanks Don..... I'm assuming your old tele number is no longer working, but if you have a new one I'll call you Monday and order them.....
Bill
