Old 02-12-2005, 04:58 PM
cobrashoch cobrashoch is offline
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
Dom- Drill a hole in the pan and stick a universal dip stick in there. They usially have a o-ring on the outside and draw up with a nut inside the pan.
The hardest is part marking the dip stick to the level you need.
I just did the same thing to a Jeep with headers, and had to do some creative bending on the tube to get it through the headers. I cut down a extra long reach dip stick out of a old Dodge van and used the stock bottom markings.
If you want there are higher cost kits from Milodon, Moroso etc. that seal up to the pan a bit better and use a screw in tube that can be trimmed.
Many catalog racing pans don't have provisions for a dip stick. I'm guessing that it is done on purpose because each application on a universal pan sold is different, and oil sticking it is a really, really simple thing to do.
Don't forget to check for windage tray clearance of you are using one and you choose to come in high on the pan.
cobrashock
Ron Shockley
