Old 02-13-2005, 12:57 PM
tony martin tony martin is offline
Send a message via AIM to tony martin
Default SPRINGS
DENNIS,
NO SPECIAL TOOLS NEEDED.
JACK UP REAR OF CAR. PUT ON STANDS.
ROMOVE REAR WHEELS.
PLACE THIN PIECE OF WOOD OR CARDBOARD ON TROLLY JACK.
JACK UP ON DISC CARFULLY. U JUST NEED TO JACK VERY SLIGHTLY UNTILL THE SHOCK STARTS TO DEPRESS(MAYBE ONLY 1/4")
THIS IS TO TAKE THE SPRING PRESSURE OFF THE SHOCK BOLT.
UNSCREW THE SHOCK BOLT AND REMOVE.
LET THE JACK DOWN.
APPLY A BIT OF PRESSURE ONTO THE TRAILING ARM, DOWN WARDS.
REMOVE THE SPRING.
MAKE SURE THAT THE TOP SPRING ADJUSTER IS CLEAN AND FREE. IF NOT CLEAN AND LUB WITH COPERSLIP OR SIMILAR.
REVERSE THE PROCESS. DONT PUT THE OLD SPRINGS BACK!!! A FEW GUYS HAVE DONE THIS!!
RE ADJUST JOUR RIDE HIGHT AFTER DRIVING SLOWLY AROUND THE BLOCK.
HAVE A WONDERFUL COBRA DAY,
DRIVE SAFELY,
REGARDS,
mr lucky
